disable pim iproute sharing
disable pim {ipv4 | ipv6} iproute sharing
Description
Disables the PIM ECMP feature.
Syntax Description
iproute IP Route
sharing Equal Cost Multipath Routing
Default
Disabled.
Usage Guidelines
None.
The following command disables the PIM ECMP feature:
disable pim ipv4 iproute sharing
This command was first available in ExtremeXOS 15.3.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
